Advice sought for isolating cistern please
28 Nov 2010
Edinburgh
I'm soon to fit a back to wall type toilet. The cistern sits on top as normal but the cistern inlet will be hidden by the toilet when it's in position. I feel it's always good to be able to switch off water to the cistern near the pan but with a tiled wall behind it and a worktop above, nowhere makes one easy to access.
What is normally done with this type of toilet to isolate cistern close by? Is it ok practice to have to pull the whole toilet forward (on a flexi) to reach an isolating screw or would a small plastic access door be a better idea?
The good concealed cisterns have internal isolators accessible through the front panel. This enables work to be carried out on them once installed.
Do not fit anything which means you subsequently have to rip out half the installation to get to the serviceable parts.
http://www.thomasdudley.co.uk/concealed-cisterns/
It's not a concealed cistern but once the toilet is pushed back flush with the wall you couldn't access the inlet easily without moving the whole toilet forward
Been trying to decide whats best this morning and still not too sure. A 200x150 access hatch (smallest I could find) seems a bit overkill to reach one isolation screw!
I just looked at the cistern. There's a weird "u" shaped cut away (about 1.5" square) near the top at one side where the cistern would sit against the wall. I'm guessing this might be a small cut away to position a valve behind. Bit high up though to take a feed to top of cistern then down again to inlet. This is probably a plan to solve my problem I guess
Normally you would install the inlet pipe close to the soli and then a flexi connector to inlet, which will be hidden behind the toilet.
Yes, you would pull the toilet forward to access
Is it mains or tank fed?
If you needed to do anything that didn't require pulling the toilet forward ( unlikely) you could turn off the cold main or cold feed else where
Hi
It's mains fed. Sorry didn't reply earlier on I was out tackling it. Although admittedly slightly convoluted, I ran the copper feed up to this cistern "gap" in the back of it so as an isolating valve screw was accessible here. It's a rented flat and I like the idea of knowing you can isolate it before either putting the water off elsewhere or having to pull the whole assembly forward.
Curse my dad for buying this toilet off gumtree rather than my usual b&q 49.95 treviso!
