Many thanks for reading this.
Having seen a few online videos about removing old grout from bathroom wall tiles with an angle-grinder and a diamond disk/blade (mine is 2mm thick), I thought I'd give it a whirl on some grout in a tile area of only between 9 tiles in my bathroom in an area out of sight.
Well, the grout certainly came out quickly, but even trying to keep the angle-grinder steady, a slight deviation by the odd millimetre off-line has resulted in a few chips and, on one tile, shaving off some of the tile itself.
Does anyone have any tips for how to NOT chip/shave off bits of tile if using a grinder to remove old grout? I mean, is there a way of keep the grinder dead straight as you go? Or should I be using a 1mm blade -- I've heard Bosch do such blades for metal work, so wondered if there was something similar for grout/mortar?
Any help would be greatly appreciated!
Thanks!
Thanks!
