The bottom 12 inches of the two wooden posts that form the frame of my garage door have rotted away starting from where the wood meets the concrete floor. I have bought an offcut of 70mmx70mm post to replace just the bottom section of each post as this will save me the much bigger task of removing the garage door and supporting metalwork.
My question is what is the best way to join the new post sections to the existing posts once I have removed the rotten sections? There is an iron bolt / pin sticking up from the concrete that used to go through the centre of the post (now completely rotten away) and so this makes sliding the new section in more difficult and I can't use anything that protrudes too far from the wood as this will catch the door and will spoil the look from the front.
I'm not a big DIY expert and don't have a mass of tools so the simpler the solution, the better.
Cheers in advance for any advice or help.
