I have recently purchased a house that has been derelict for a number of years, my circumstances have changed since I purchased the house and I'm now living in a mouldy damp falling down health hazard.
Externally I need to repair/replace the roof & gutters and repoint and re render the walls to make it water tight.
Once this is done there is a lot of work required inside. I'm unsure on the order that things should be done.
Basically I need to take it back to a shell and start again. The ceilings are falling down (large holes every where and new bits fall down every day), the floors are rotten (big patches of floor boards I know not to step on as my feet go through them) and I'm sure the floor joists are rotten too. The boiler does not work and there is mould all over the walls, even a few mushrooms sprouting here and there.
So I know I need to strip it out, then put it back together again, but really need advice as to the order I do the internal stuff. When stripping out I want to remove an internal (load bearing wall) to make the ground floor open plan.
So work I plan on doing is:
1. Replace floor joists (use a builder)
2. Replace floor boards
3. Remove radiators
4. Remove load bearing walls (use a structural engineer and builder)
5. Take other walls back to brick and take ceilings down
6. Open up old fire and chimney that is covered over (reline by a contractor) and install log burner (this has been donated to me)
7. Replace boiler (use a contractor/gas engineer)
8. Move sockets and lights to where I want them due to new layout (do i need an electircian or can I do this myself?)
9. Move plumbing for kitchen to new location
10. Move gas for kitchen to new location (use a contractor/gas engineer)
11. Plaster board and replaster throughout walls and ceilings
12. Install new radiators (the current ones are full of black muck)
13. Install old kitchen cupboards into new location (paint the doors to freshen them up) and appliances
14. Decorate
15. Furnish
Have I got the order right?
As I said earlier, when I purchased the property my circumstances were different, but now I find myself having to tackle this without a lot of money, while living here too. I'm hoping that I can do a lot of the stripping out myself and only pay people where absolutely necessary to put things back in (structural, gas, electric) trying to learn a lot myself through advice forums and online videos.
Any advice would be greatly appreciated.
Thank you!
3. Remove radiators
14. Decorate
15. Furnish
Thank you!
