Hi, just wondering if I could get some advise on plastering/filling over wires (see pic below)?
On the left is where an old socket has been covered with a piece of wood (used to be behind some fitted wardrobes that we just took out) and as you can see the cable is still there. On the right of the picture is the new double socket, the cable has a metal cover over most of it.
Is it ok to put plaster/filler straight on top of cables? Should I PVA the area and then fill with patching plaster?? and if so, do I need to build it up in layers? it's just that for the new socket the gap at the top is quite deep. Many thanks for your time.
