Hi just need some advise on removing a en-suite in order to make the bedroom bigger.
I'm ok with removing the shower/sink and partition walls, my main problem is removing the toilet, what should be done with the toilet waste pipe. Should it be removed completely ? or is there an alternative method ?
I would like to remove the pipe completely. I think the waste pipe from the toilet goes under the patio and connects to a vertical waste pipe outside of the house. However there is also a drain near by which it might go to directly
How hard would it be, to remove the toilet waste pipe ?
if the task is too hard would i need a plumber or builder to do the job, as i guess the work would involve digging part of the patio up and also around the vertical waste pipe/drain to disconnect the pipe.
Any help would be much appreciated
Kin
Kin
