I have changed the mid position valve on my Ideal Classic System, having drained the system to below the level on the valve, changed valve, and then refilled and bled system. All rads getting hot fine upstairs and down but when its firing up first thing in the morning, there is about 5 seconds worth of air gurgling sound at pump/valve area. Also at the nearest rad to the pump there is still a tiny amount of air which ive been bleeding out on start up. Will this clear itself as this is only 12 hours after changing the valve or is there anything else I can try? There is a piece of verticle copper pipe with a square tap on the end by the top section next to the mid postiton valve. What is this for? Thanks in advance.
