Hi all, looking for a bit of advise and hoping someone can help. My loft has been boarded out by the previous owner and they don't seem to have done a good job of it. The joists are 3 x 2 and when I walk in there I can feel it flex and the ceilings below have cracked. I only plan on using this for a bit of storage space.
From what I can see there appears to be 3, 3x2's that run the length of the loft (approx 15ft). Screwed / nailed to the underside of these appears to be a series of more 3x2's that hold the ceiling. Someone has put chipboard on top of these and called it a day. Leaving the three 3x2 lengths protruding obove.
There are also some large timber beams that run the length above the floor at approx 45 degrees. Picture below to help illustrate what we currently have.
I have seen this post which mentions gluing and screwing an additional 4x2 on top of 3x2. With just having the 3 beams running the length of the loft area is this a viable option? I could do that, add some 4x2 noggins and board over? As I say this is only ever going to be used for light storage. But needs to stop the ceilings cracking when I walk around in there and feel a bit more robust.
