Advise on conversion
11 Aug 2008
Bedfordshire
I've submitted plans for conversion of my internal garage into a kitchen. This involves raising the floor to match the house level. The garage external wall is single skin and a new interior cavity wall is required. The garage door will be removed and a small wall built with window above it. Above the garage is an existing bedroom which formed part of the extension above the garage prior to me buying it.
I've got some builders in to do the job but I want to make sure its done right.
For this type of job what would you expect them to do?
I might be being vague so I can clarify further if needed.
I would expect them to follow the submitted and approved plans
as it is permitted development it did not require method statements simply elevations of existing and proposed.
Did you really need to apply for planning permission?
What about the building regs were plans submitted for that?
If not, then you need to pass the risk to your builders via a contract - stating that they are to design and build to the current building regulations.
The probelm you have, is that there are various ways of compliance, and you need to ensure that the builders are quoting for similar work, else the prices could be misleading
Describing what they are expected to do will take an age. Search the building forum for garage conversion posts
Ah I see. I suspect I didn't need to apply and it was always going to be subject to BC. However I didn't want to take the risk. It didn't cost me a great deal.
I will speak to them and see how they plan to do it and check with BC that they would approve.
Ulitmately I won't be selling this house for 20 years+ so I imgaine it could be acedemic?
