We are having a whole new boiler/system/pipework and am after some advise with regards to the type of setup we need.
We have a largish 4 bed victorian semi which is going to have 2 bedrooms with en-suite, a family bathroom, a downstairs toilet. Going to have 14 radiators, 2 possibly 3 showers(will not be electric), 1 bath, 4 toilets and 5 sinks.
I have replaced the water pipe to the main with 25mm MDPE which connects to the water meter so the pressure/flow rate into the house should be good
From the research I've done, it seems we need a regular or a system boiler.
Our plumber is a viessmann-installer so we will get the 5 year warranty.
We are looking at either the viessmann vitodens 200-W 35kw or the worcester greenstar 40cdi. I am not overly sure as to the benefit of either except the extended warranty. Any others worth considering?
The main issue is the that we have a attic conversion which has an en-suite with shower which will be above any gravity-feed tanks that are in the other part of the loft.
As we want the showers to have good pressure/flow and not be electric, our plumber has suggested either a negative-head pump or a pressurized cylinder. I'm not really sure what to go for as I'm starting to get well beyond my limited knowledge.
Any advise on what set up to go for would be gratefully received.
Jim
Jim
