Hi - on several of the washing cycles, the machine has not tripped into the next phase of washing, ie stuck in washing cycle. We had thought it was the heating element, but that's been checked and is ok. We wonder if it is a temperature sensor / thermometer as water not heating sufficiently and causing programme to become stuck and to finish washing, I have to halt the programme, and then select next stage.
Each phase works but not automatically - pump out / spinning / rinsing.
If it is the water temperature sensor (if there is one?) where can it be located?
If it is not, what else might be causing the problem?
Any help will be very much appreciated - thanks!
