AEG 75578-KG3 side by side Fridge Freezer - how to separate
7 Dec 2020
We have a 2009 AEG 75578-KG3 side by side Fridge Freezer that we need to separate. We have located the 2 rear top and bottom and front bottom joining brackets but cannot find the top front bracket. The FF control and display is behind a chrome cover running across the whole top front of both units and has no obvious way of being removed (we assume there could be a hidden joining bracket under this).
SOLVED:
After no help at all from AEG Electrolux and lots of head scratching from forum members and everyone I know finally a colleague came up with the idea of pushing a screwdriver under the chrome cover from the rear which released a series of plastic clips and the whole control panel popped off in one piece revealing the last metal joining clip (front top). The control panel electrics were connected with a number of box and spade connectors leaving the front 5cm x 5cm x 1.25m control strip as a completely separate component. I now have a separate fridge and a separate freezer that can easily be moved to a new home. Thank you to everyone that offered help.
