AEG bearings gone - worth reparing?
6 Feb 2006
Hertfordshire
hi, I'd love some washing machine advice, as I know v.little
We have a 6 1/2 year old AEG Lavamat 72620 which has just started spinning very noisily... Also there was smoke coming out of the drum and an acrid burning on the last spin I did.
A bit of web research and reading on this forum plus my DIY nut Dad looking inside the machine confirms that the bearings almost certainly need replacing.
Calling AEG doesn't really seem to help as they are reluctant to give any advice without you calling someone out. Their parts dept quoted me £160 incl. VAT for new parts after I said the bearings needed replacing.. but looking at the cost of bearing kits on the web, I can't believe this was just for a new bearing kit.
I'd really like some advice about whether or not it's worth going for replacement parts/repair.. and if so, what parts should I need? OR whether to chuck it and go for a new machine. (it would have to be another AEG, Bosch, Siemens or something like that).
In my mind PROs of repair:
- I love my AEG
- Probably still a bit cheaper than a new quality machine
CONs of repair:
- Looks like I'd have to use AEG engineer - potentially quite expensive.. even DIY nut Dad didn't fancy helping me do a DIY repair!
- Unknown factors..What's the smoke all about - is it just the bearings or....?
- Machine already over 6 years old and had lots of use/ we live in hard water area - perhaps better in long run to get a new machine?
Well some advice from someone who knows about washing machines would be GREAT
thanks
josie
get new m/c
changing bearing is easy with the right kit, if you havent got it, good luck
