We had two rings playing up on the cooker. A month ago I obtained a new regulator which was slimline with slightly different pins but found everything was ok keeping a careful eye on the marks on each one. Thought it was time to fix the last one but this is giving me problems because it is last in the line and has extra wires.
The original regulator is as follows:
S - blue
S (double pin) - 1 blue
4 - thin with black line
P2 (double pin) - thin, no line top; grey bottom
2 - thin red line
P1 (double pin) - thin, blue line top; brown bottom
The replacement regulator has the following pins:
S1, S2, P2, Pilot, 4, 2, P1 (double)
So the pins I'm stuck on are the original 2 S's and the original double P2.
Would really appreciate it if someone could point me in the right direction.
Thanks,
Alan.
S - blue
2 - thin red line
Thanks,
Alan.
