AEG Dishwhasher i40 + leak?
23 Feb 2013
London
My AEG dishwasher an f55002vi0p keeps coming up with a pressure sensor i40 fault casuing the drain pump to run all the time.
I've taken the bottom of the unit and there was some water/yellow goo in the tray, it hadn't activated the polystyrene switch as I could push that up to check it was activated. Which part is the pressure sensor so I can try and replace it?
Could the leak be an overflow caused by a blocked pipe in the system?
Video is here
