- Joined
- 15 Feb 2021
- Messages
- 3
- Reaction score
- 0
- Country
Can anyone advise. AEG HC5960M extractor unit - 3 speeds + 1 intense speed + 2 lights.
Extractor been working perfectly for past 17 years. Six months ago the fan would fail to turn on Low speed. Mid and High speeds working fine. Solution was cycling thru the speeds back to Low speed and fan would operate. Until yesterday that is, now fan not working at any speed. Only buzzing sound coming from unit. Both lights work as normal.
Dismantelled the whole assembly. Loads of grease, have cleaned everything up. Had to undo most of the wiring in the control unit to release the fan for inspection. The motor itself looks OK, took the rotor out - doesn't look as if it's burned out. Re-connected the various parts - I haven't connected the fan to spindle ( to eliminate the fan as causing the motor not to turn ).
Switching unit on and same buzzing sound is heard but motor not turning. Can hear the system click when I select each speed setting and the volume of buzz increases, but again motor doesn't turn.
This is where I need some advice. I guess only the control panel, circuit board, capacitor or the motor itself can be at fault ( perhaps more than one? ). The control panel appears to be working and given I hear clicks each time a different fan speed is selected, I'm assuming the circuit board is OK. Could something as simple as the capacitor be at fault or do you think it's just the motor? Is there anything else I can check?
Cheers.
Cheers.
