Hi All,
I have one AEG OKO LAVAMAT 41260 (Prod. Nr. 913 760 251) that sometimes (without any error code) doesn't finish washing or stops for a lot of minutes, then starts again.
For two times it is also burned the triac that controls the motor.
I've used the procedure written on the "AEG 72630 Update" topic, even if the model is different.
My machine says "E52" at point 18 and "O-2" at point 19.
Is there a way to be sure that is it a problem on PCB?
Do I have to replace the PCB? I've discovered that it is no more available.
Is there another way to do not buy a new washing machine?
Thank you!
Thank you!
