Having a problem with the washing machine.
It stops mid-cycle and displays error E10.
I've already checked the cold supply filter & pipe and they are both perfectly clear. Before re-connecting the cold fill, I did test the flow rate and it filled a bucket in less than 10 seconds, so I know that's not the problem.
I then read parts of this forum and found how to perform an error code check on the machine.
It gave a stored error code of E11 on the spin position.
I know it's something to do with the water fill system. So could it be a blocked pipe to or from the control solonoid?
Or even a faulty solonoid?
Any thoughts anybody?
How easy is it to take the top casing off and have a good look at the guts of this machine?
Tony
Tony
