Hi all, hope somebody can help with this one. I am just starting to fit a kitchen and have got around to fitting the wall units. The walls in the kitchen are thermalite blocks with a plaster finish (not boards). The cupboards are the 1000mm units, so quite heavy. I am just not sure which is the best method of fixing them to the walls would be as these blocks are crumbly and nothing seems to bite to them.
I have got a tube of resin as I think that anything I use will need to be fixed in with a chemical bond. Would frame fixings be OK?
