I am sure one can make a slim jim aerial from some 300 ohm ribbon which will work A1. I really enjoyed playing with aerials and transmitted 5 watt on a 300 ohm ribbon slim jim.
I note you can get combiner and splitters for FM, DAB, TV, SAT so sure you can combine two aerials without any need for traps in the dipole.
It really annoys me to see modulation type (FM) and use (TV) mixed on same unit. My radio is marked with such a variation FM, AM, LW, MW, SW, Wide, Narrow, Mono, Stereo, (in spite of only having one speaker) BFO on/off with BFO pitch and RF Gain I wonder how many ever use all of these controls it's only a standard world band receiver which I use to take abroad with me for news etc.
Think some one pressed the "Execute" button as no longer works although more likely lack of batteries. With all this range what aerial well just a bit of long wire. Longer the better no need for cutting to special lengths for most stations OK for SSB maybe needed better aerial but you will note with all the letters saying what it receives it does not actually say single side band but with the BFO it would receive it.
Although there was a big push for DAB I think it has run out of steam. UHF with freeview and satellite broadcast the same programs as DAB only advantage of DAB is car use. So unless you can pick it up with a simple car aerial then no point in having it.
I have been in one car fitted with DAB and to be frank it was useless had to switch to FM as it kept cutting out or use the phone and internet which worked far better although eating into allocation. Road was a high open road E22 or A55 the longest road it would seem Holyhead to Ishim well past Moscow if it will not work on such a major road then it's dead and soon broadcasters will give up and shut down transmitters it's just a waste of band width.
