We are going to be having some major work carried out to our house shortly and I was planning to run some extra cables to various rooms for future use, either for sky or just off the main aerial.
We currently have normal sky and a main aerial, the cables from both follow the smae route into the house and terminate at the same point in the livingroom. I was planning to run 4 or 5 new lengths of cable, while relocating the 2 existing cables very slighty so that they will run internally between the existing external wall and a new wall for the extension to a cupboard where the sky box, dvd, etc wil be located.
Plan was to leave the cables under the floors/in the walls in 3 bedrooms and study for when I need/want to connect them to the aerial/sky, with the feeds loose in the cupboard.
I also want to upgrade from normal sky to sky+, so will need a second cable from the dish.
Does anyone know if sky will accept a cable that I run from the dish location to where the receiver box is located, for them to come along and just connect it up? If so, what type of cable should I use?
Also, am I missing a trick inw hat I am thinkig of doing? The puupose of the extra cables are to provide a tv feed (either just from the aerial or sky) to the study and also, at a later point when the kids are older to their rooms.
cheers
cheers
