Morning All
Im in the process of going through my house fitting wired internet access, DAB and TV points in all the rooms. (theres nothing at the minute except a coax direct from my aerial, straight down the front of my house, into the living room, minging!) I was just wondering if anyone could help about the following points:
1. Im fitting these Diplex plates and am I right in thinking, I run the coax from both TV and DAB/FM aerials into my attic, connect it to an amp (pictured), then just 1 single coax is required from the OUT on the amp to run the diplex plate for TV and DAB. (as there is only one input into the diplex plate) Im using the PF/WF100 Coax as it seems to be the best at the minute. Im happy working with coax.
2. Is this AMP pictured a decent one? (im happy its got enough outputs, I was just wandering about the brand/quality). The attic is powered as im also wanting a network switch up there too.
3. Is this aerial ok (pictured) for DAB and FM signals?
Any suggestions/thoughts would be great.
Kind Regards.
(DIPLEX PLATE)
(AERIAL)
(AMP)
Kind Regards.
(DIPLEX PLATE)
(AERIAL)
(AMP)
