I recently purchased this mixer bar.
The fitting instructions that came with it are barely existant and go no further than telling you to connect the cold inlet pipe to the blue side and the hot to the red side!
Anyway, as far as I can see the only mechanical support is from where the two inlet pipes connect to the back. The connections on the shower are a standard tap connector thread, into which two pipe adaptors are screwed in. These adaptors are threaded on the other end to allow a 15mm compression nut and olive to be used to grip the inlet pipe.
Now, I am just wondering, should the supply pipes really be used to give support to a fitting? There is no other way this mixer could be fitted, I really just want someone to be able to say "Oh, that is how they all mount on the wall!" so I feel more confident with it!
