After fixing oven light Oven will not work
1 Apr 2010
Surrey
I have a John Lewis oven. Electric wall mounted eye level. (Model JLBIOS601) I was replacing the light bulb. Tested it and it worked. I replaced the glass cover and the entire housing turned and turned, resulting in the wiring from the rear of the fixing coming loose.
Earth was still in place. However there is a white and a brown wire and it loops to the fan and these were detached from the fixing. I did not unplug the oven from its socket, and as I was removing the fixing, one of the wires shorted / sparked. I have since replaced the wires into the fixing. Now the following problem exists. When I plug the oven in, the clock comes on in front and the little orange light next to the clock labelled "oven" remains lit. The oven does not turn on. The internal oven light nor the fan nor the grill - nothing turns on. What could be the problem?
Rish
