The house we have moved into has an Aga. This has a water outlet used as a secondary water heat source - secondary to the main boiler. It also feeds a small radiator. This is a conventional, open vented, gravity system. The large bore piping used must be a major source of heat loss.
Is it possible/ safe to install a control valve in this pipe work just outside of the Aga. The objective being to cut of the gravity circulation when this secondary water heating is not required? Might there be any overheating or safety issues. Should the control-valve be in the cold return - expansion tank pipe or in the hot output - overflow side.
All advice appreciated.
