AGE Competence Oven Cutting Out
26 Jun 2006
I have the above oven which I have had for about two years. Recently it keeps cutting out on me. It will work from cold for about 20 mins before the oven cuts out and the internal light goes off. The power light on the outside stays on but the temp light goes off. I have tried turning it off and resetting it etc but nothing seems to fix it. Has anyone had a similar problem or any ideas?
i have seen this before. it could be that the heat sensors on top of your oven near the cooling fan have packed up. when the oven turns off if you leave it on will it come back on of its own accord after a while?
That is exactly what happens. Is that the thin metal bar right in the top back left corner? Is it an easy job to fix or replace it?
