- Joined
- 22 Jul 2016
- Messages
- 6,006
- Reaction score
- 1,117
- Country
Yes I have looked and much of the info is quite old.
I have done a small amount before but want to DIY a semi industrial method to speed it up.
in the past I have used white spirit to soften the bitumen on some recycled blocks.
I also did the freezer and chip method.
I have about 300 blocks to do.
my plan is to remove as much bitumen as I can by some method before using a thicknesser to standardise the blocks. The thicknesser is nearly brand new and belongs to work so I can’t use it for the bitumen removal for fear of covering everything in gunk.
Has anybody managed to develop a technique that was efficient?
one idea is to modify my black and decker electric plane that hardly gets used to become a semi thicknesser. Possibly upside down (in a frame) to mechanically remove the bitumen. My fear is that the blades will heat the bitumen and not work. The plane is able to be sacrificed if it works.
option two is to use the good old manual scraper but make a sort of 4 wheeled dolly to get the 20mm block fit under the hand scraper blade.
i could make sort of tracks /guide rails for the wheels and pack the height.
option three is the nylon paint stripping discs, used to remove paint from metal. Angle grinder used, maybe generates heat?
I could try the solvent route with white spirit /paraffin. This takes time to work, May be actually quicker than mechanical means, given the construction time.
if I could obtain some liquid nitrogen (!) or dry ice (more likely) I have seen a guy lay dry ice on a car floor in order to freeze the sound deadening bitumen and then hit it with a hammer to break it. I do know about dry ice blasting but not possible.
last option is a paint shaver? I only discovered this yesterday. £200+ but potentially quick. It is basically a milling machine made to remove tiny amounts and therefore a tiny amount of wood also.
thanks!
i can live with mind numbing tasks but a bit of speed would help
thanks!
