Please help !!!
I have just moved in and have a Baxi Combi 80e.
After re-fitting the rads I was able to start the boiler no probs.
(I had to drain the system when taking the rads off and I didn't have a key to bleed the rads after re-fill).
I noticed that two rads (front upstairs and front downstairs) were not warming up at all, even from pipes. All rad values and RTV's are open.
Later, Next day I bought a rad key and bled the air from all of the rads.
Now my problem is, when I try to start the boiler.
The burner fires up (with the burner light lit amber on the boiler panel) then after a second it cuts out. This cycle is repeated. I get no red lights on panel.
Things that I have already tried since...
I've reset the timer and boiler
I've drained the system
The Auto Air Vent bleed screw was already open on the pump, which I've checked/closed.
Your thoughts please ?
