Following a home extension, an external bathroom became an internal bathroom and the building regs required the installation of an internal soil stack fitted with an air admittance valve. There's a constant foul smell from the cupboard next to the bathroom, in which the soil stack is housed. Most of the time it's a mild odour, that I can only describe as rotting veg, but this can get significantly stronger, though I don't know what triggers the variation. The soil stack has recently been boxed in but this hasn't made the smell go away. If anything it's generally a bit worse. I'd appreciate any thoughts on what's causing the smell and advice on how to eliminate it.
There was an additional bathroom built above the extension and again the building regs required a soil stack to be installed. This one was sited in the eaves space using the same AAV, a FloPlast AV110. There's never been any odour from that one.
I'm in Scotland in case you're wondering about the building regs requirements.
