- Joined
- 9 Feb 2005
- Messages
- 299
- Reaction score
- 5
- Country
We have had a new toilet fitted nearly where the old one was which results in 2 90 degree bends before it takes a 90 into the floor.
When the toilet is flushed, the pan fills up with water before emptying slowly. An air admittance valve was fitted which had no effect so it was moved to the other side of the toilet where it still has no effect.
If I stick my finger inside the valve and push the flap up, the toilet works fine every time but an unpleasant niff is blown out before drawing air back in.
The plumbers gave up on this and left. I thought of fitting a 32mm vent to outside but the builders have frowned on this idea.
Any suggestions?
Any suggestions?
