Help required please.....
I have a downstairs radiator running only slightly warm when heating system is on.
I think I have a air blockage on the return pipe, from the downstairs radiator, as this is cold as it rises up the wall??????????????????.
The feed pipe is hot as normal???.
I have a drain down valve under this radiator and have been told that I can connect the hose from mains water supply to move the air blockage??.
Are there any extra precautions I should take before commencing with this procedure and how much water should I feed into system.
What are the implications and any faults with doing this?.
Its a conventional standard open vented system with boiler and pump with header tank in loft.
Many thanks....
Many thanks....
