Air brick extensions
4 Aug 2012
Kent
I have 2 air bricks on my house, that when I build the extension will themselves need to be extended to the new outside walls.
Is there a standard way of doing this?
Currently the air bricks are right under the damp course level on the house and id I extended them as is, then the new concrete floor screed would have no cover at all. So I'm going to lower them by a single brick as I have room for this.
Would it be OK to put them to the nearest outside wall, on the side, or do them have to go to the new back wall, which would be a longer run?
Go to the nearest outside wall.
You can use either 110mm drain pipe or flat ducting.
There are telescopic air vent ducts available that will enable you to duct vertically form the sub floor.
You really need direct through-ventilation, so the airbricks should go on opposite walls (ie front and back of house) not turned 90° to a side wall
Don't lower airbricks, just knock a hole lower down (at hardcore level) and slide your 100mm drain pipe right through, then gob it up to make good
Use those ducts as per above, but connect the pipe to the duct with a proper round-to-rectangle adapter
Thanks guys, has great and I'll duct right through
100mm pipe might be an issue though, due to it's large size. I want the new air bricks to be just a brick down from the damp course and 110mm migh be an issue. Once I have he 150mm of hardcore in place, then the 100 of concrete, I'm left with 70mm of celotex and 65mm screed. There wont be much cover over the top of the pipe if I lay it onto the concrete
Can this ducting go down beween the cavity of the two foundation walls, then duct fully through to the original wall? The 2 foundation walls will be filled with a lea mix anyway
As it's said, a picture paints a thousand words, than you very much, I can 'see' it now
