Hello all knowing ones!
I live in an end terrace built circa 1895. It has a cellar and stone built walls. The House is built on a slope so the cellar height goes from a few cm's at the front of the property to 5ft ish at the rear. There is one entrance door on the outside of the property to access the cellar. I am having some minor damp...spot mould etc. and have been advised to install some airbricks (currently only one at back of property). This seems a very small job to get a builder in to do but being a stone built property the walls are actually very thick so I am not sure if it would be too much for a competent diyer to undertake? Also is there any formula for how many I should install? Would leaving the cellar door open give enough ventilation or would you all put in the airbricks?
Cheers
Cheers
