Air brick / vent
8 Feb 2009
Berkshire
Hi there,
I live in a 5 year old house and have two vents in my lounge where the external air bricks are located. I open these vents whenever I light my woodburner to get the required up-draught in the chimney and avoid smoke leaking back into the room during lighting. There is quite a cold draught so should these be left open or can I close them after the woodburner is lit?
Is there a better solution?
Many thanks
Ian
I don't understand how a properly sealed woodburner leaks fumes back into the room. I light mine, shut the door and thats it. Smoke couldn't reenter the room if it wanted too.
Yes its sealed but when I tried lighting without the room vents open the smoke leaked from the woodburners air-wash vent on the top right (it's not a tight seal as its metal against metal).
Cheers
Ian
