I was wondering if someone could advise me on the following - Recently moved into our new house and found that it was suffering from significant condensation issues. First thing that I checked was the air bricks. The air bricks that I have are the pretty standard perforated jobs, and when I checked them from the outside it appears that the perforations have been plugged with what looks to be purpose made orangey brown, barbed plastic plugs. behind these plugs there appears to be what I can only describe as a 'carpet like material' - which I assume is some sort of membrane. Can anyone advise me what this might be? I believe it is probably preventing adequate ventilation, but I don't want to remove it if it is there for a good reason - because once I remove it I probably won't be able to put it back without removing the outside grate.
Cheers in advance,
Russ
Cheers in advance,
Russ
