Cheers Legs, I think your first explanation was correct , I had floated the wall with the browning but it was taking ages to go off I was in a hurry to get the job done so I decided to skim up while the surface was crusty to the touch but when I pressed on the stuff it left an indentation. I will not do that again. By the way ,any thoughts on why the browning took so long to go off? at its thickest point it was about 1 inch deep.
Incidently I plastered up my first room today just skimming over existing plaster that had been knocked about a bit when removing woodchip wallpaper. There are two walls 12 foot by 8 foot tall and two walls 10 by 8 with a window and door , using multi skim I knocked up a buket of plaster and started to spread it on the wall, no sooner had I finnished the bottom of the wall and started on the top section the plaster had started to go stiff, I used clean water and everthing was spotless and I was chasing it all day like that and boy my arm is falling off. Got it done though so well pleased with myself
