Air conditioner thermal efficiency
25 Jan 2004
I'm considering buying a portable a/c unit. I have done the calculations and reckon I need a 12,000 BTU unit (which is also called a 1-ton unit).
But, nowhere seems to be listing what the power draw of such a unit is! I understand that it will vary depending on humidity, air temperature and temperature drop required, and I know that the unit I am looking at runs from a 13A plug.
So, does anyone have any anecdotal information about the energy requirements of an air conditioner?
Air Conditioner - 12000 BTU Review in Air Conditioning at Review ...www.airconditionershack.co.uk. Cheap Mobile Twin Pipe Air Conditioner with ... 12000 Btu/h (1350W), Approximate running cost is 12p per hour, 12 hour timer.
Ah, well found that man!
I had googled but with little fortune, thanks for that.
Adam, You are welcome.
It is unlike you to miss out when searching, I always look at you as the man that if he dosnt, will eventually.
I'll blame it on the heat and the fact I don't have an airconditioner :LOL:
