- Joined
- 18 Apr 2022
- Messages
- 3
- Reaction score
- 2
- Country
I'm building a garden room and am about to build the timber floor frame. I will be insulating between the joists with foil-backed PIR board. I have seen many tutorials where the PIR board is installed flush with the top of the timbers, so that the plywood floor base lies on top of the timbers and board. But this would not leave any air gap between the plywood and the foil face of the PIR board, so you wouldn't get any radiant heat reflection back into the room. I am planning to install underfloor heating on top of the plywood, so radiant heat reflection back into the room would be very useful.
Is there a problem with installing the PIR board with a 20mm gap between the foil face and the top of the timbers? It will effectively be sealed when I lay the plywood on top.
Thanks for any help or advice.
