Hello all,
I've spent several hours browsing through previous posts to see if I could get some direction, but none of the suggestions in them has allowed me to remedy the problem.
The system is open vented, gravity fed with a Potterton Suprima combi boiler, unknown (no label) hot water cylinder/immersion heater, Grundfos Selectric pump, Drayton 3 way actuator/valve and 9 radiators.
Three weeks ago I drained down the heating system, and installed TRVs on all of the radiators except for the one in the hall where the thermostat is mounted. The water in the radiators wasn't dirty when I drained it down and I used a cleanser, flushed the system several times and filled it using an inhibitor. I bled all the radiators, tested all the new TRVs and everything was working as expected. So far so good.
Except now when the hot water program kicks in morning and evening, the pipework between the pump and the hot water cylinder/immersion heater makes all kinds of gurgling noises for several hours. I've checked to make sure the Feed and Expansion tank is filled and functioning properly, and have repeatedly bled the radiators, pump and the bleed point on the short vertical riser above the 3 way valve. These are the only bleed points I can find in the system.
My questions really boil down to these:
-Are there any other bleed points I should be aware of?
-Should I 'crack the nut' on the top of the cylinder/immersion heater to release any air potentially held there?
-Several earlier posts seemed to point at a failing 3 way valve/actuator as the culprit for these symptoms. Does that sound reasonable? It seems somehow suspect to me that the valve would choose to fail just when I changed out the radiator valves, but I suppose it's possible.
Any direction you could give me would be greatly appreciated.
