I've recently replaced my Grant Combi oil fired boiler with a new Worcester Bosch Combi gas boiler. I installed the entire OIL boiler system 3 years ago and it had been functioning well until I decided to change to gas on cost basis. With the agreement of my nominated Gas safe registered fitter, I modified my existing pipework (all MDPE with Hep2O push-fit connectors and all new radiators bar one, 3 years ago) to run a short distance to the new gas boiler. The gas fitter ran the gas pipe from the meter and installed the boiler and joined it up to my (hot, cold and CH) pipework. Since then, I have had to drain it and refill it twice (new radiators added). On each occasion I cannot remove all the air from the system. One of the radiators in the house (there are currently 6 downstairs and 3 upstairs) sounds like there is air bubbles running through it and when I bleed it, I get a small amount of air out and then what looks like aerated water (slightly cloudy but clears once sitting for a while). More air seems to migrate to one radiator upstairs as I would expect but no matter how many times I bleed the system, I still get the noisy radiator downstairs.
Any ideas?
Any ideas?
