I wondering if you can help? I always get air in the pump. It is at its worst when the heating or water is switched on. As the pump runs for a while the noise of the air in the pump reduces. I moved in about 2 months ago and the problem has always been there. I can see no visible leaks in the heating system. I have tried just running the HW and OR heating and this has no effect. I have also tried shuting off all the RADS to see if that had any effect. The expandation tank if full. I have a Baxi Bermuda 552 back boiler with 6 RADs. The hot tank is on the top floor along with the pump which has two motorised value below it connecting the HW and heating. Any help would be greatly appericated.
Many Thanks
Matt
Many Thanks
Matt
