Hi
First time posting on a subject I do not know much about so please be patient!
I have air in my radiators. If the heating is on all day then the living room radiator fills with alot of air.
The setup is as follows:-
I have an oil fired boiler which has 2 pipes going into the hot water tank and 2 which supply the central heating. (6 radiators)
I have a tank in the loft which seems to only supply water to the hot water cylinder. I cannot see any pipes supplying the cntral heating?
There are no leaks at the pipes coming from the boiler but I have not managed to check all the pipes under the floor yet.
The tank in the loft seems to use water all the time with a steady flow coming out of it into the hot water cylinder indicating a leak somewhere.
When I bleed the radiators the water comes out black.
What I am looking to find out is the cause of the air but also that if air is bled from the system then does water replace it and where does this water come from as I said there seems to be no connection of water to the central heating system.
Want to at least try and find out as much as I can before going to the expense of calling someone out.
Many Thanks
Mike
Many Thanks
Mike
