Air in Rads
24 May 2005
Dear all,
I have had 2 rads repalced, 1 is a tall colum type the other is a towel rail. The problem is every coups of days, they need bleeding as the tops of the rads go cold and fill with air. Anybody have any ideas?
J
Could be hydogen gas due to corrosion. Did you use inhibiton when you refilled system after doing the work.
i read it as just had 2 rads done... i suppose it depends on how long that means !
of course u could be right
I am not to sure about the inhibitor, would it work if I added to the system now, and how could I check if it was hydrogen?
J
bleed some out and have a flame ready. it will light !
when did u have the rads put in
