I have a 2-bar shower pump mounted at the base of the hot water cylinder on the same floor as the shower. 22mm pipes go from the pump to the shower via the attic. A Surrey flange is fitted at hot water feed at the top of the cylinder. This system worked well for many months but has developed a problem. The pump momentarily stops during operation. After each stop, the shower runs cold for a second or so before the hot water arrives again. Also, when the shower is switched on for the first time it runs cold at reduced pressure for 5-10 seconds until the hot water arrives and the pressure visibly increases.
It seems as if air is entering the hot water circuit somehow causing the pump hot water flow sensor to drop out. The initial running cold seems to suggest extra resistance in the hot water circuit due to air having to be pushed through it. But I'm just guessing. I have inspected the pump hot water impeller and it looks fine. The filter is clear.
Does anyone have an idea if this cou;ld be due to air and if so, how is it getting into the system?
