I am having problems with air in two radiators upstairs, I have a closed system using a Halstead Ace High combi boiler . I have to vent air from the radiators weekly. Is this normal? what can I do to cure?
its caused by chemichal (yes i know) reaction beetween dissimalar metals put a cleanser in the system for a couple of days when you flush it out add inhibitor should sort it
Who put the system in? If it wasn't you, get in touch with them. Did they treat it at the time? If they didn't,. they could have left you with a potentially expensive problem.
