air in system
5 Sep 2007
Can anyone help?
I have attempted to refill my sealed system and have got pressure up to 1 bar after bleeding all rads. I then ran the central heating for a couple of hours and then re bled rads and left the system overnight.
This morning the pressure was back at zero.
There are no leaks so i am a bit stumped.
Any suggestions??
Refill, bleed, refill if ness, bleed again and top up if ness.
If it's at zero again, youve got a leak.
Thanks for the reply. I have refilled and beld the system again. Will see what it is like in the morning.
See FAQ's for possible problems with the Expansion Vessel. You may want to check the discharge pipe aswell. ;)
