air in water tank - mixer taps
11 Aug 2009
West Midlands
I had to drain my water system yesterday and now I think I have an air lock in the system. I have heard that I need to run a pipe between the hot & cold tap to move the air lock - unfortunately I have mixer taps everywhere - any ideas on how to get rid of the air locks ?
the upstairs is gravity for cold, downstairs is mains fed for cold and hot is gravity fed for upstairs and downstairs
Cup your hands over the sink mixer. Have someone else put a towel over your hands. then turn on Hot tap followed by cold.. Then while you`re stuck there :cool: . The cold will blow back through the hot.
thats sounds like fun - i will have a go - any idea how long this may take ?
try it for 30-40 seconds then let go turn off the cold tap and if successful you will get cold running back out of the hot tap followed by a surge of air then the hot water, let it run for 1-2 mins just to make sure all the air is out, if not do it again, then go and change out of your wet jumper cause when i do it i usually end up getting soaked.
