Air into closed system CH?
22 Feb 2008
Southampton
Is there any way air can be getting into a closed CH system?
I'd fitted a new PRV, X800'd the system and flushed it a few times, X100'd it and refilled it to 1.3bar and vented the all rads. Run it a few times and vented the rads again and filled it back to 1.3bar.
After a few days the pressure had gone up a couple of points. Re-bled the highest rad to find more air in it. 'Ok' I thought 'lets see what happens' .
Took some more air out of this same rad again today rather surprisingly.
In the past couple of days the boiler/pipes have started to be a bit noisy again (like vibration noise) whereas it was completely quiet after I did all the work.
Any ideas?
Next time you bleed a radiator see if the air smells of eggs or if you purt a match to it it pops. If so then it is not air getting into the system but hydrogen building up.
Hydrogen is a by product of corrosion in the heating system. To stop the corrosion and hydrogen build up add a corrosion inhibitor. :)
Could just be air in the system left in there from the original fill up. You could have missed venting it out the first time.
I put a lighter to it and I think it did pop, now what?
I did add a litre of Sentinel X100 inhibitor when i refilled the system 10 days ago. Should I add more? (8 rads (three bed semi)
No that's enough. Just let it circulate and do it's stuff. You may need to bleed some rads for a little while yet, but it will stop. Patience is a virtue! :LOL:
LOL It's definately hydrogen, I set light to it as I bled the rad and burnt the heck out of my thumb trying to close the bleed valve :evil:
At least I know for sure now.
