I'm a bit of a noob when it comes to all this, so please bear with me
Recently had the pump replaced in the CH system (Grundfos 15-90N I think) and since then, there is a decent amount of air trapped in the system - you can hear it swooshing through the boiler and especially at the pump next to the hot water tank.
The plumber who fitted the pump came round and drained the system and that seemed to remove the air temporarily, but the problem came back the next day.
His theory is that the air separator (small grey thing behind the Grunfos in the pic below) could be filled up with rust (quite a bit of black water came out the old pump) and it's exacerbating the problem by not really separating the air.
Any ideas how to troubleshoot this before taking the step to remove the air separator? I've bled the radiators off frequently, and it seems like the air that's bled off just keeps getting replenished.
It's an open-vented system, with a header tank and expansion tank supplying 9 radiators. Pics below of the tanks pipework:
Tanks in the loft
View media item 82962Hot water tank
View media item 82963 [/u][/b]
Tanks in the loft
