Plumber moved the cold tank only a couple of feet but since then the hot and cold water has been locking off. Hot water cylinder is on ground floor and cold tank in the loft. We often got bubbles in the pipe in the past but never no water, which has now happened twice in one week. Solution is to hold hand over kitchen tap to force the main up the hot, and hose up the bath mixer to sort out the cold. Not ideal!
Because this never used to happen is there possibly an air lock I could clear by draining and refilling the system? I can't believe the movement of the cold tank is enough to cause it, or its a bit of coincidence to suddenly start happening
Cheers!
Cheers!
